Front brake conv. ??
OK looked at the FAQ section and never noticed any ?? on using any of the brake parts from the vans or is it a total different suspension.My neck of the woods its hard to find 2 wd stuff ,but I know where a van is sitting
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Front brake conv. ??
Just be careful.
The van parts are a little lighter duty than the 2wd pickup parts. That is: a G10 van is like a super light C10; a G20 more closely resembles a C10 squarebody. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
OK Thanks
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would suggest a G20 van for a disc brake upgrade. The few that I have seen have a different LCA shaft than a C10 Squarebody. Be aware that the G series van steering boxes will not work for a power steering conversion if the box is mounted almost vertical with the pitman arm to the rear and pointing down. Those boxes turn the opposite of a pickup box.
Yeah thats what I was wondering so are the K10/20 steering boxes a good choice ?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 01-13-2021 at 11:02 PM. Reason: Brain tumor |
![]() Join Date: Sep 2006
Just get some later model spindles and ball joints. You can find them on RockAuto.com if you like. Here I used 75 model spindles on my truck. Shows parts also. http://www.67-72chevytrucks.com/vboa...isc+brake+swap
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
You guys are awesome , Chevy Fleetside I read your post last night and thought Hell Yeah wasn't looking toward the engine removal for a complete crossmember swap at all maybe I can score some of these parts on my budget. Did you go with the same year 75 for the booster?
60-66 Nut
NO. You can not use a K series steering box and pitman arm on a C series truck. The box casting is the same but the sector shaft is different.
#9 | |
I thought the G20 spindles are pretty much the same as the C10. I was looking at how to lower my G20 and people use the C10 drop spindles.
#10 | |
60-66 Nut
Thank you. There are many,many,many boosters that are compatible with all of my booster brackets. Just not the squarebody boosters. Those have the factory mounting brackets riveted to them
![]() Join Date: Jul 2000
Back in the day, I used 86 C10 spindles, rotors, and calipers on my 69 C10. But I also had to use a 73-87 C10 center link and tie rod ends.
Bought used spindles and center link for a song at a junkyard. Also found a used master cylinder, prop valve, booster, and mounting bracket from a 71-72 pickup. That was around 25 years ago, when junkyard parts for our trucks were plentiful. MPBrakes makes a complete kit for your 69 C10, but they are not cheap.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#13 |
What booster would be a good candidate for this ?
#14 |
The factory used a single 11" booster, but an aftermarket dual 8" will work.
A stock one would have looked like this but was spaced out from the firewall with a bracket. Master cylinder bore diameter was 1-1/8" with power. Manual was probably 15/16" or 1". ![]() Here's a dual 8" setup from MP Brakes. They also make a dual 9". These guys make their own brackets using an actual firewall and pedal assembly in the process. Their pre- and post-sales support is second to none. https://www.mpbrakes.com/booster-mas...m-booster.asp? ![]()
#15 |
Keep in mind that your engine will need to make at least 16" vacuum at idle for use with a vacuum booster. MP Brakes might even say 18" minimum for best performance.
#16 |
Awesome ,got the ol gal fired up yesterday it has a 350 in it,now I need to move on to brakes and trying to decide what to do .The master cly. is toast so may just jump over to the power disc setup . OK 1 more ? if I do the spindle swap to newer wont that make my front a little wider than the rear?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 01-16-2021 at 02:14 PM. |
#17 |
If there is any difference, I've never noticed it. 255-70x15 tires on 8"wheels. I'm talking about 73-87 spindles, center link, and tie rod ends.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-16-2021 at 10:10 PM. |
#18 |
I picked up a g20 last sumer I was thinking about using it for disc brake conversion cross reference spindles and a arms on rock auto listed them as the same
G20s also use the 1 1/4 hd brake rotor Another member on here posted 73 77 elcamino inner tie rods with 73 87 outer tie rods will fit the 67 70 center link I ended up with a complete 72 running gear for my build |
#19 | |
![]() ![]() ![]() Join Date: Jan 2018
The 1/4" extra on each side doesn't bother me at all. If it did, I would just add a 1/4" spacer to the stock rear end
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
