Old 01-13-2021, 09:07 PM   #1
Riverstory
What is this access hole for?
I borrowed this picture from KENS65FB (thanks) and I have the same access hole on my 1966 passenger cowl.
Does anybody know what this access/pass through hole is for? Thanks
Riverstory is offline   Reply With Quote
Old 01-13-2021, 10:39 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What is this access hole for?
Probably a registration hole for when the fender is stamped. But I could be wrong.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-15-2021, 05:50 PM   #3
Wrenchbender Ret
I believe it is a feed hole for an original antenna lead.
Wrenchbender Ret is offline   Reply With Quote
Old 01-15-2021, 07:45 PM   #4
Afirehawk1
Yep the antennae
Afirehawk1 is offline   Reply With Quote
Old 01-15-2021, 07:59 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
The antenna mounts on top of the cowl and feeds into the cab above the passenger's side kick panel, right? This truck's cowl appears to not have been pierced for an antenna. Not that my registration hole guess was right.
~Steven
Simi Valley, CA
Old 01-15-2021, 08:09 PM   #6
Afirehawk1
I added a photo where access point is.
A grommet goes there with the antenna passing through
Sorry for quality of photo
At least this is where mine is located
Not sure if accurate
Old 01-15-2021, 08:15 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I don't think it's for the Antenna:
The antenna hole comes up under the cowl cover.
66 C20 Service Truck:
Old 01-15-2021, 08:16 PM   #8
LostMy65
LostMy65's Avatar
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=596341
Old 01-15-2021, 08:31 PM   #9
LostMy65
LostMy65's Avatar
Also look at this thread - It has an antenna with nothing through that hole. And it has holes on both sides.
http://67-72chevytrucks.com/vboard/s...28#post5405928
Old 01-15-2021, 08:37 PM   #10
Riverstory
Agreed that there are holes on BOTH sides.
