Old 01-14-2021, 01:45 PM   #1
AngryPirate
AngryPirate's Avatar
Dropping steering column to access turn signal switch
So, I’ve already undone the 4 bolts on the bottom plate, that holds the steering wheel up and removed the parking brake cable but this only buys me an inch of working room.
Before I go and unbolt and detach everything under the sun, is there some particular items that need to be undone so I can get access to that one Phillips head bolt holding the turn signal switch in place?
The placement of this switch so frustrating.
1960 GMC 1000 series, 3 on the tree.
Thanks for any pointers.
- Scott
AngryPirate is offline   Reply With Quote
Old 01-14-2021, 01:59 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Dropping steering column to access turn signal switch
Try loosening the clamp on the engine side of the firewall. That might give you enough room to drop it down some more
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-14-2021, 02:01 PM   #3
AngryPirate
Thanks cwcarpenter98! I will try that now.
Old 01-14-2021, 03:52 PM   #4
AngryPirate
That did the trick! Thanks !
Old 01-14-2021, 08:44 PM   #5
cwcarpenter98
Sweet! I'm glad my guess worked for ya
Christian Carpenter
