Old 01-27-2021, 01:46 AM   #1
85raiderburban
85raiderburban's Avatar
turn signal malfunction
blinkers only work on driver side front. bought a new flasher at the fuse box and same thing. anyone else had this problem before?
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado)
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior
85raiderburban is offline   Reply With Quote
Old 01-29-2021, 10:32 PM   #2
kwmech
Re: turn signal malfunction
Brake lamps work in the back?? Switch itself? connector loose under dash coming out of the column
Old 02-06-2021, 06:48 PM   #3
85raiderburban
brake lamps have not worked since i bought this truck 5 years ago. when trying to to put a new fuse in at the fuse box it instantly pops. I checked the connector under the dash its plugged in nice and snug.
Old 02-06-2021, 07:07 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
I'd test switch with a multimeter and make sure it's not shorted.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-06-2021, 10:58 PM   #5
franken
Brake lights use the same filaments as turn signals in the 1157 bulbs. They're also more important than turn signals so that's the place to start. The same flasher is used for both sides so it obviously isn't the flasher.
Time to get out the multimeter, wiring diagram and troubleshoot.
franken is offline   Reply With Quote
