Hella H4 housing conversion?
Time has come that I need to replace several of the headlights in my '85 Sierra Classic, and I'm not opposed to buying the Hella (or other brand) conversion housings that accept a replaceable bulb. It occurred to me, I could modify the wiring so that all four burn on high and low beam. Pretty sure the standard H4 bulb is 55W/60W for low/high beam - will I run into any problems in the capacity of the factory wiring if I have 110/120W running all the time?
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Re: Hella H4 housing conversion?
I just sold my CUCV Project and was going to use these Hella 1AE 003.427-011 H4's. I'd sell the pair for $100 shipped.
I was planning to run one of the aftermarket Relay Kits to eliminate the load on the factory harness so might be some thing to consider. http://48cj2a.com/images/forsale/202...7-011%20H4.jpg http://48cj2a.com/images/forsale/2021/Hella/Hella.jpg
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
Relay mod for the WIN even stock.
And for the love of god dont tell me you wana be a a$$hat and run 4 low beams if i read your post correctly . . . Ford has that on there trucks now and to oncoming drivers its HELL . Dont know how it passed fmvss testing . I skipped the mods and hella parts and got j.w.speaker led units . D.O.T aprooved and wow nice white and true defined cot off on the patterns over cheep china led units. And gained a ton more side view at night . No one flashed me yet with them adjusted correctly . Been around 4 years now . Plus they draw a lot less power so no relay mod required .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Run a relay that is triggered by the high beam supply wire to switch power through the relay from a good fused 12V source to the low beam feed wire.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
#5 | |
81 and up come factory quad light to do 2low and 4 high . So the low on with 4 high i dont see much extra left to get .
