Old 03-14-2021, 02:33 PM   #1
Vicente Aceves
What did my truck look like?
I just bought a 74 GMC 1/2 ton shortbed pickup.
The previous owner had it for about 15 years. He bought it the way it’s painted currently.
The SPID says 556 Grecian Bronze/White
B85 Upper Custom Mldgs
Z62 Custom Deluxe
Can anyone tell me what the “White” part of the 566 code means? Was it the roof originally?
I’d also like to know what the Upper Custom Moldings are?
And what did custom deluxe get you originally? I know it’s a lower level trim. I just don’t know how “base” of a trim level it is.
Any help is very much appreciated!
Thanks Vinnie
Vicente Aceves is offline   Reply With Quote
Old 03-14-2021, 04:14 PM   #2
Vicente Aceves
Re: What did my truck look like?
I’m not a fan of the interior, so I’ll be on the look out for original or original looking interior pieces.
Old 03-14-2021, 05:09 PM   #3
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Hi Vinnie,
Nice score on a California smog-exempt square. The white is the color of the roof,ending down the A & B pillars. The trim is on the cab, below the rear window. These trucks were pretty basic.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 03-14-2021, 08:05 PM   #4
Vicente Aceves
Thanks. That’s what I wanted to know!
And yes, I got lucky on a pre smog truck. . It’s been on non-op for over ten years. Not much rust at all. It did come with a pretty nasty motor. Maybe too much for everyday driving.
Old 03-15-2021, 11:59 AM   #5
Vicente Aceves
Based on the SPID, would my instrument cluster bezel and the long dash bezel insert have been wood grain originally?
I’m just trying to figure out what to keep my eye out for so I can bring it somewhat back to a stock appearance inside.
Old 03-15-2021, 12:02 PM   #6
Vicente Aceves
Here are better pictures. Thanks
Old 03-15-2021, 01:57 PM   #7
MJN
MJN's Avatar
The dash insert would have been wood grain along with the door panel inserts. The instrument cluster bezel would have been black on yours. Much of the information you're looking for can be found here; https://www.gmheritagecenter.com/doc...olet-Truck.pdf
The 1974 info packet in basically the same but the '73 packet explains the RPO's and packages better.
The B85 moldings is just the upper trim that runs along the body line of the truck, this also included trim rings around the turn signal, side marker and tail light lenses.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-15-2021, 04:17 PM   #8
Vicente Aceves
Thanks for the info!
