03-15-2021, 05:56 PM | #1 |
Z bar removal
Can someone tell me what I'm missing? How does the z bar release from the bellhousing?
03-15-2021, 06:18 PM | #2 |
Re: Z bar removal
If I recall correctly, there should be a depression (flat side) on each side of the ball-stud which allows you to get an open end wrench on it to screw it out/in to the housing. You might need to degrease/clean the area to get a better look at what you are working with. If you are removing/re-installing, I highly recommend replacing all the "wear" parts (studs, seals, clips etc).
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-17-2021, 09:47 PM | #3 |
Re: Z bar removal
loosen the bolt on the frame side, and it should move up, and out of the bracket. then you can pull it off the bellhousing knob.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
