03-15-2021, 06:06 PM | #1 |
Power Steering Pump Assembly Question
All - in the photos below, do I have the correct fitting orientation against the spring or is it the other way? I want to make sure before re-assembly. Thanks for your help in advance!
Where can get the seals for the 2 studs with the hex heads and the black seal for the large nut? |
03-15-2021, 06:22 PM | #2 |
Re: Power Steering Pump Assembly Question
You can get a seal kit from any parts store. It has the o-rings & the shaft seal.
Its been so long I can't remember where the spring goes but I'm thinking its between those parts. George |
03-15-2021, 06:39 PM | #3 |
When I originally took off the nut the fitting came flying out so the spring was first installed - but I'm not sure what is correct. Thanks for your input
03-15-2021, 07:02 PM | #4 |
Flow control spring goes in first, then the flow control valve.
03-15-2021, 08:58 PM | #5 |
Bigbird - OK is the valve oriented correctly? Thanks for your help!
03-15-2021, 09:04 PM | #6 |
Yes it goes in just like you have it.
03-17-2021, 01:27 PM | #7 |
Thanks BB
