03-17-2021, 12:04 PM | #1 |
What are these ?
Asking for some help from the community...
What's this electric vacuum switch? It's not the Idle A/C because that's on the other side of the carb and verified working. There was no vacuum off it, so I bypassed it. It goes to a T that splits to carb and a canister at the front of the truck. Then, there are these, one on each side of the engine bay. Any ideas? ..
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
03-17-2021, 12:13 PM | #2 |
Re: What are these ?
I think the first pic is the TCS (Transmission Controlled Spark) solenoid...
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
03-17-2021, 01:19 PM | #3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=652526
Jim |
03-18-2021, 05:42 PM | #4 | |
At the risk of starting an argument, From the distributor advance to manifold or ported vacuum? I've read in other threads that there was a switch from manifold to ported as a band aid to reduce emissions...
03-18-2021, 09:13 PM | #5 |
Who Changed This?
There was a thermal switch on the thermostat housing and an electrical switch on the transmission for the TCS system. Once the engine was warm enough, the thermal switch would allow vacuum, but the switch on the transmission would not enable vacuum until in high gear (3rd for an automatic, 3rd or 4th for a manual). I think that it was also ported, but it's been a long time since I worked on those. The solenoid on the intake manifold depended on the switch on the transmission providing ground to engage and allow vacuum to the distributor. If anyone wants to argue ported/non-ported, that's on them.
03-19-2021, 01:33 AM | #6 |
Early attempt at NOx control. It only allowed ported vacuum to the distributor once the engine was warmed up and the trans was in high gear. Manual transmissions got the AIR pump. Never saw tcs on a manual truck that I remember. This was in California anyways when I had my smog license a few years back. BUT it also varied by the GVW rating of the truck
03-19-2021, 10:35 AM | #7 | |
72 C10 lwb fleetside -stock 350/350 combo |
