03-17-2021, 12:26 PM | #1 |
1970 K10 Drag Link bent?
Hi, the picture attached is my 70 k10 original axles drag link. I'm curious if it is bent or if it's supposed to have the curve in it. Thanks for any help!
03-17-2021, 12:31 PM | #2 |
Re: 1970 K10 Drag Link bent?
Bent.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
03-17-2021, 01:37 PM | #3 |
Proprietor of Dale's Corner
X2, your tie rod is bent..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-17-2021, 01:42 PM | #4 |
AND get rid of those tall blocks welded to the housing.
03-17-2021, 03:57 PM | #5 |
All about them K’s
+1 blocks up front are a major no-no!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-17-2021, 08:04 PM | #6 |
Definitely bent. Go to rock auto. They have them for pretty cheap. Just bought some ball joints from there that were $35 cheaper than the parts store. Name brand, too.
03-18-2021, 03:52 PM | #7 |
I do not know any where that reproduction tie rod bar for 67 72 trucks
You will probably have search for a good used bar |
03-18-2021, 05:01 PM | #8 |
03-18-2021, 05:50 PM | #9 |
https://www.motorcityk5.com/i-13758-...=category:9428
There's also the same P/N on amazon that is a little cheaper too. |
03-18-2021, 06:27 PM | #10 |
Thanks guys, blocks are coming off lol! Someone got carried away years ago! I have a 71 Suburban parts frame ill pull the sway bar off of that, it has a drilled hole for a steering stabilizer so I'm wondering if it's for a square body. Time to get the tape measure out!
