Old 03-19-2021, 06:46 AM   #1
gsharp
Big Block Transmission
I'm running a BBC 454 with a TH400 transmission with the original rear end and 295/50R15 tires. It runs and drives great but it revs pretty high at 60 mph. I believe the factory gears are 3.73. I want to install an overdrive transmission but I've read that a 700R4 won't hold up to a slightly built 454. So I've looked into a 4L80E which would work great but then comes the issue of not having a controller. They want huge money for a stand alone or you can build some kind of homemade one. Anyone have any experience with this?
gsharp is offline   Reply With Quote
Old 03-19-2021, 07:17 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Big Block Transmission
Find a 4l80, not the electronic, that will live a lot longer behind your BB than the 700 will
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-19-2021, 06:06 PM   #3
jayoldschool
Moderator
All 4L80s are electronic. You can get a stand alone controller out of a van, some had separate PCM and trans controllers.
jayoldschool is offline   Reply With Quote
Old 03-19-2021, 10:08 PM   #4
Captainfab
60-66 Nut
I would suggest the 4L80E. Yes the controller and a TPS add up to some money. But you could get away with running a good used 4L80E versus spending $$$$$ having a 700R4 built to hopefully hold up behind a big block. The other issue with an electronic trans is the speedo is electric also. There is no speedo cable connection. There is info online on how to wire a factory ECM to operate an electronic trans as a standalone. That could be an option if you have more time than money
Old 03-19-2021, 11:24 PM   #5
shsahs
shsahs's Avatar
Its pricy but there is the Gear Vendors route.
My 1966 Chevrolet C10 Pickup
shsahs is offline   Reply With Quote
Old 03-20-2021, 09:43 AM   #6
urmyboyblue
Another alternative is to change the gearing in the rear and run taller tires. This will kill RPM but also probably reduce acceleration some. When I have looked at a 4L80, it was almost a wash with buying a Gearvendors.
urmyboyblue is offline   Reply With Quote
Old 03-20-2021, 03:31 PM   #7
shsahs
shsahs's Avatar
That was why I mentioned it. Unless you stumble on a heck of a deal on the transmission and the electronics it can get quite expensive. Where the gear vendor unit is pricy you do have a brutally strong unit that can be moved to as many transmissions as you can destroy. lol
Old 03-20-2021, 08:51 PM   #8
gmc684x4
You can run the ecm the 4l80e came with
Sloppy mechanic lays out how to do this
https://sites.google.com/site/sloppy...ans-controller
gmc684x4 is offline   Reply With Quote
Old 03-21-2021, 01:53 AM   #9
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Find Early Diesel Step Van And get Harness And Ecm works perfect
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 03-21-2021, 09:34 AM   #10
Clyde65
Clyde65's Avatar
A CableX box works to change speedo from electric to cable
Clyde65
Rebuild of Clyde
support our troops!
Old 03-22-2021, 02:27 PM   #11
vin63
It's Better With Nitro
vin63's Avatar
I run a US Shift TCM with my 4L80E. I think the Quick 2 unit and harness (TPS) are around $600.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
700r4
