Parking Lights
I have several older cars / trucks and they all have the front parking lights turn off when the headlights turn on.
I was just curious why older vehicles front parking lights turn off when the headlights turn on. I ordered a new headlight switch today from GMC Paul and noticed I was able to buy the older switch (67-68) that would turn them off or the newer (68-729 that leaves them on. |
#2 | |
Re: Parking Lights
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#3 | |
Re: Parking Lights
Re: Parking Lights
I'd say they were for parking, not driving. I rewired the park lamps in my 51 to be on with the headlights, they were so dim you couldn't see them with the headlights on. So I put them back the way they were.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Parking Lights
I agree. That was long before DRLs.
If that's not the right answer, we're both wrong. ![]()
Re: Parking Lights
so I finally had a little time to start checking the wiring to try and get my rear parking and brake lights working. I can not seem to locate the harness connectors that are shown on the diagram. where would they typically be located. I did find the three connectors at the rear, but nothing intermediate between the rearmost connector and the firewall junction box.
![]() Join Date: Aug 2019
Re: Parking Lights
Going from front to back the first connector is inside the cab at the firewall (round), the next connector is in the rear cross member, left side (also round) from there you have individual connectors on the left and right and center for the light bulbs.
#8 | |
Old member
![]() Quote:
Drivers side lights: Brown: is parking, tail lights, side marker and tag light. Light Green: is drivers side backup light. Yellow: Drivers side brake & turn signal Passenger side lights: Brown: is parking, tail lights, side marker and tag light. Light Green: is passenger side backup light. Dark Green: Passenger side brake & turn signal
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#9 | |
Re: Parking Lights
Re: Parking Lights
The problem ended up being a combination of a bad turn signal switch and very poor grounds at the rear light fixtures themselves. I added a 10ga wire from the Light Fixtures to the frame and they work great now. Thanks for everyone's help.
