70 K10 and front disk brakes
I've been told that the best way to add power disks to my 70 K10 is to put in a complete axle from a 73 and up square body. Can anyone give me some pointers on what axle and years to look for? My truck originally had manual drums and was converted to power drums.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: 70 K10 and front disk brakes
A Dana 44. You might be able to find one with the right gear ratio.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#3 | |
Here's a thread where I posted some pictures of mine. Mine is a K20 but you'll get an idea of what it looks like |
#4 | |
All about them K’s
![]() Join Date: Jun 2014
Yes sir, that the one year ‘70 only open knuckle drum brake dana 44 axle. You can convert it to disks here’s a decent post from a thread concerning this from a while back. I’ll add the post and the thread both.
Post- http://67-72chevytrucks.com/vboard/s...1&postcount=14 Thread- http://67-72chevytrucks.com/vboard/s...d.php?t=207507 The thread has a few ways to skin this cat. Hope that helps.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
73 to about 81 ish will have a a dana 44 not sure which year in the 80s they switched to a 10 bolt front diff
It should bolt right in with exception of shock mount locations Good chance to find one the same ratio |
