04-05-2021, 12:30 AM | #1 |
Post Whore
Brake Pedal Return Spring Pictures Please
Could someone kindly share some pics of what the brake pedal spring mounts to, my '54 came with a Camaro front clip already welded on so I have no idea where it attached to, please and thank you
I did search the forums and seem so have found pics of the 55.2-59 setup which may have the spring going rearward but I don't think that's correct |
04-05-2021, 01:56 PM | #2 |
Re: Brake Pedal Return Spring Pictures Please
It should go forward to the spot it connects to if you are running the stock pedal.
I took a few photos of my frame and you should be able to use one or more of the measurements to get your spot. 19 inches from the front of the cab mount bracket where it hits the frame or 16 inches from the front of the original master cylinder bracket that rivets to the frame
04-05-2021, 04:57 PM | #3 | |
Post Whore
