04-06-2021, 07:39 AM | #1 |
Enjoy your truck
‘63 Rear springs
I know I am likely going to get differing answers but I am going to ask anyway - what should the height from the ground to the underside of the rear wheel opening be for a ‘63 C10 fleet side long box, with standard coil springs?
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
04-06-2021, 12:50 PM | #2 |
Moderator
Re: ‘63 Rear springs
They (GM) show a stepside for both step and fleet dimensions. I copied the fleet section for you. They don't show wheel well height.:
04-06-2021, 01:02 PM | #3 |
Enjoy your truck
Thanks for the response.
I am trying to determine if my 20+ year old rear coils are needing to be replaced or not. Ideally I would get a measurement from ground to wheel opening lip as it is a pretty consistent area of measurement for similar trucks.
04-06-2021, 01:10 PM | #4 |
Moderator
Or I could find the L measurement for you. 28.25" unloaded (curb weight).
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-06-2021 at 01:18 PM. |
04-06-2021, 03:35 PM | #5 |
Enjoy your truck
Mine is 28.75” and it appears to be lower than when I had the springs installed, but that was 20+ years ago and you know how time messes with your recollections.
04-08-2021, 07:49 AM | #6 |
Enjoy your truck
Maybe I am asking for the wrong measurements. I thought the wheels opening would be easy to measure.
Could anyone give me the height of the rear coil springs as they are installed on the truck?
04-12-2021, 04:53 PM | #7 |
Enjoy your truck
Anyone?
04-12-2021, 10:14 PM | #8 |
Tire size will have an effect on your measurement. I have 29" tall tires on stock springs. I'm sitting at about 27 1/4" from ground to wheel well lip. Then again, I did have a probably 200+ pound steel plate on top of the rotted out wood floor for who knows how long
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
