04-06-2021, 09:03 AM | #1 |
Loss of power on acceleration when warm, backfires a lot.
I have an 87 Suburban with a 6.0 LQ4.
For a while now, when the motor is warmed up, when I go to accelerate sometimes it will bog down and not want to move. When this happens it backfires like crazy, and if I keep the accelerator pedal pressed once the RPMs finally get up the truck will accelerate and get up to speed. When I did the swap 5 years and 16,000 miles ago I replaced the spark plugs, plug wires, fuel filter, ignition coils, and MAF sensor. I did not replace the fuel injectors. I have a fuel gauge mounted to my fuel rail that shows a constant 58 psi at idle. I do not have any check engine lights or any stored codes. Any Ideas where to start?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
04-06-2021, 10:46 PM | #2 |
Re: Loss of power on acceleration when warm, backfires a lot.
Sounds a lot like a fuel pressure problem. I would hook up the gauge and check pressure while under load if possible. Maybe change the fuel filter if it hasn't been changed in a while.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-09-2021, 06:02 PM | #3 |
Old and crusty
Not sure why you aren't getting any codes. Running that poorly should trigger some response from the computer.
My truck with 5.3Vortec motor was running like crap for a while, including some back firing and very rough idle and poor throttle. The only codes I was getting was lean condition on the left bank. I tried a few basic tune things to no avail. One day I decided to take off the bracket that holds the coils on the left side just to clean things up and inspect the coils. I had already installed new plugs and wires. One of the coils was cracked on the bottom side and could not be seen unless it was removed. I had some spares so I changed out the coil and it runs perfectly again.
65 Chevy long wide daily driver - SOLD! 64 Chevy Short Step LS |
07-12-2021, 01:22 AM | #4 |
Do you have a way to see which cylinders are misfiring if they are misfiring?
Posted via Mobile Device |
08-02-2021, 09:48 AM | #5 |
Update:
Since I started the thread I have replaced the Camshaft position sensor, Crank sensor, and MAP sensor as these were all not replaced 5 years ago when I did the swap. Did not change anything. I never did have a ck engine light until two weeks ago I got P0175 rich on bank 2. Cleared the code came back a few days later. I have a constant 58 psi fuel pressure at idle. It seemed to only do this when under load and when the engine was warm. Even worse with the AC on. Then I replaced the Mass air flow sensor and still no change. Two days ago I replaced the spark plugs and plug wires again (were replaced when I did the swap 5 years ago). Now it seems like it is fixed. I have driven it about 60 miles and seems like the problem was solved. When I inspected the plugs they weren't fouled out/black and all 8 looked the same. If it comes back I will keep everyone posted. Thanks for the help.
08-02-2021, 12:43 PM | #6 |
Post Whore
dont you just hate chasing a problem...then find its something simple
08-02-2021, 04:41 PM | #7 | |
My next two steps were to replace the throttle body, as I was thinking the Throttle position sensor was the problem. If that didn't fix it, I was going to pull the motor and fully build it and make it a beast.
