Old 04-06-2021, 06:24 PM   #1
Gregski
Post Whore
Gregski's Avatar
Steering Column Intermediate Joint Thingie Identification
hi guys I don't even know where to start with this thing, can someone please tell me what it is called and can it be replaced with a U joint of some kind, I don't see the shaft being D shaped so I don't know what to do
worst case scenario I just need that rubber boot or gator what ever it is called and I can repack it with some Crisco grease and send it
Gregski is offline   Reply With Quote
Old 04-06-2021, 09:26 PM   #2
Gregski
Post Whore
Gregski's Avatar
Re: Steering Column Intermediate Joint Thingie Identification
so I guess that thing is called a coupling, and I found this thread on something similar
Rebuild a steering shaft grease boot
however this video has me wondering if we are missing a spring
Steering Shaft Coupler Rebuild | Pot Joint Boot replacement | Vega EP19
Old 04-07-2021, 08:52 AM   #3
Katrina/10
Katrina/10's Avatar
I believe it is called a pot joint. Looks like the rubber master cylinder cap may work well, but I haven't tried it. Those joints are actually a good thing, because it is a slip joint and allows movement between cab and frame without binding the steering shaft.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-07-2021, 11:44 AM   #4
Gregski
Post Whore
Gregski's Avatar
Thank you so much Gary, I really appreciate the explanation, do you think there should be a spring in mine like the guy had on his Chevelle, I am not positive since these can mount in both directions and his mounts upside down from mine
and I ordered this kit for the rubber boot really
Old 04-07-2021, 12:39 PM   #5
Katrina/10
Katrina/10's Avatar
I just watched the video, it's quite good. As for the spring, I don't know for sure if yours came with one or not. But, I don't think it would matter if you don't have one. The spring would just preload the joint, maybe to keep it from rattling. Would not be a function or safety issue without it. I might order one of those boot kits, glad you found that.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
