Old 04-16-2021, 10:13 PM   #1
lutronjim
6an male to 5/16 inverted flair
Just installed an Entropy radiator and put in flex steel lines and fittings from Fragola. One of the radiator fittings had a leak - found that the hex 'head' had bottomed out before the flair seated.
Called Entropy and Tony suggested a Summit fitting that had 'longer' threads which solved problem. Part # SUM-220668B
lutronjim is offline   Reply With Quote
