Old 05-12-2021, 05:11 PM   #1
54blackhornet
54blackhornet's Avatar
VO910THP Pad # ?
I would like to decode this # located on passenger side front head location.
VO9 10 THP
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-12-2021, 06:48 PM   #2
HotWheelsFan
HotWheelsFan's Avatar
Re: VO910THP Pad # ?
Quick search shows:
THP 1971 307 conv. cab, m/t 200hp 2bbl C-20 to 3500
Looks like a good start... Does not seem out of line for a 1970 or 1971 date cast on the small block.
HotWheelsFan is offline   Reply With Quote
Old 05-13-2021, 11:24 AM   #3
MJN
MJN's Avatar
V 0910: Flint, Mi September 10
THP: 71 307 Truck 200hp manual trans, L14 RPO, 1 2bbl carb C20/C30 application
Looks like GM may have reused this code later on too according to my suffix code book but The Lime Book doesn't list THP for anything but the '71 307.
https://www.ncrs.org/ok/LIME_BOOK_2018.pdf
1985 350 Truck 165 hp manual trans LS9 RPO 1 4bbl carb C/K 10-30 application
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-13-2021, 11:43 AM   #4
54blackhornet
Thanks so much guy’s ! Looks like I have the original engine in my 71 C/20 , 307, 2 brl, stick , conventional cab. The little 307 still has its engine lift brackets in place.
71 C-20
07 Magnum RT AWD
Old 05-13-2021, 11:57 AM   #5
geezer#99
geezer#99's Avatar
Casting number will confirm it.
Old 05-13-2021, 03:05 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
1985 350 block would have the dipstick on the passenger side.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-13-2021, 03:13 PM   #7
54blackhornet
Thanks Gary, the dipstick is on drivers side. The engine has no extra accessories on it so working on it’s actually enjoyable..thanks for your help again..Jack
71 C-20
07 Magnum RT AWD
