06-02-2021, 09:16 PM | #1 |
Floor shift tilt, converted motorhome
Please respond in thread only per board rules, first "I'll take it" gets it.
$400 local, $440 shipped. Selling a converted floor shift tilt column. Made from a mid 80s GM class A chassis motorhome tilt I built this one for myself, but I'm not going for the glossy interior look so here it is. My painter just buffed it out to get a nice shine on it and take care of a couple of dust specs in the clear coat. All parts sandblasted, etch primed, and painted gloss black base/clear by my friend that is a painter. The lower bearing retainer was painted silver. I did the welding and filler work. The upper cover around the signal switch has the holes welded. The shift collar holes were filled with Wurth epoxy and set up for a few months before paint. Turn signal lever is a very nice original Turn signal switch is tight and cancels as it should. Disassembled, cleaned, and lubed with dielectric grease. It has the red hazard button and half-moon connector. Includes the cancel cam and spring Tilt mechanism is tight and smooth. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. Tilt lever is a re-pop. The threads on these are too long, so I put shrink tubing over the extra thread length. It snugs up nicely. The bottom bearing was cleaned and greased The upper bearings were cleaned and greased The shift tube was welded at the bottom to eliminate rattling.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-05-2021 at 08:28 PM. Reason: Now shipping |
06-02-2021, 09:21 PM | #2 |
Re: Floor shift tilt, converted motorhome
Tilt lever
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-05-2021, 08:30 PM | #3 |
Bump, now shipping this one.
12-06-2021, 08:03 PM | #4 |
I’ve bought nearly a dozen columns from clay68c10. He does excellent work! Buy with confidence!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
12-06-2021, 09:52 PM | #5 |
So this beauty is a direct bolt in for a manual truck?
12-06-2021, 10:53 PM | #6 |
Thanks SoCo, it’s been a pleasure doing business with you.
Tuff Gong; yes it is. You just need to put your steering wheel on. If you have a 67/68 (I think 69+ came with them) you’ll need an intermediate shaft.
12-08-2021, 12:16 PM | #7 |
6>8 Plugless........
Darn good deal here IMO!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-08-2021, 08:08 PM | #8 |
I will take this, please pm PayPal
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-08-2021, 08:21 PM | #9 |
Sending PM
12-09-2021, 06:45 PM | #10 |
Shipped
PMd tracking info
12-17-2021, 02:25 PM | #11 |
Super nice part, and shipping/packaging was awesome! Thank you Clay!
