Old 08-11-2021, 05:50 PM   #1
brian1115
Hydroboost brake bleeding?
I replaced the Brake booster in my truck with a hydroboost unit. The master cylinder is brand new and the proportioning valve is a wilwood valve. The master cylinder is bench bled correctly.
I have bled all the brakes and the pedal still feels a little spongy. If I pump the pedal about 4 times it stiffens up. The truck is not running yet and I am wondering if this is normal for a hydroboost.
Does the pedal feel stiffer with a vacuum booster vs a hydroboost unit? Will turning on the engine and having power steering fluid go to the hydroboost affect pedal stiffness?
If anyone that swapped to hydroboost can chime in that would be great thanks.
1986 Chevy Fleetside Wrangler (Canadian Only)
brian1115 is offline   Reply With Quote
Old 08-11-2021, 08:49 PM   #2
sweetk30
sweetk30's Avatar
Re: Hydroboost brake bleeding?
hydroboost not running or the 2-3 extra pumps stored used up do feel weird .
fire it for a little bit and check pedal . but also they will let you push way down past whats needed as hydroboost has more pressure assist . so you almost need to test drive it in the driveway or parking lot to be 100% sure .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-11-2021, 09:16 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
It will not bleed properly until the power steering pump is running and pumping fluid through it.
