08-24-2021, 05:21 PM | #1 |
LMC Steering column install
Hi all,
Hope you’re having a great week! I’m in the middle of the LMC steering column install and have two quick questions. 1. I can’t seem to get the stewing spline bolt seated - see picture. Any helpful hints? 2. The column comes with a grey wire separate from the harness. I thought it could be for the horn but that spot looks filled. This is different than the stock setup. Any ideas on what this could be? Posted via Mobile Device |
08-24-2021, 05:59 PM | #2 | |
08-24-2021, 10:52 PM | #3 |
Re: LMC Steering column install
you should post this in the truck section for more responses.....steering wheel and dash forward are the same as the trucks....the suspension and driveline is, also.....
08-25-2021, 12:01 PM | #4 |
Thank you! Will do.
@53burb - do you have any more photos of the paint job on the suburban in your signature? Mine goes into paint next week and I'm thinking about going that route. Thanks! |
08-25-2021, 12:22 PM | #5 |
Is the intermediate shaft on the bottom of the column all the way? When on correctly, the lower shaft of the column has a concave depression or cut out the bolt rests on. Maybe that's what's not lining up (the intermediate shaft and that bolt slot).
72 C10 lwb fleetside -stock 350/350 combo |
08-26-2021, 02:32 AM | #6 |
here is one...anything in particular u wanted??
08-26-2021, 07:29 AM | #7 |
That's perfect thank you! I'm going to send it to the painter and see what he thinks.
08-26-2021, 08:17 AM | #8 |
awesome!
08-27-2021, 09:26 AM | #9 |
Post Whore
If (And it is a big if) the new column is using factory colors for the wiring then a light gray wire may be for illumination of the shift indicator. It would splice into the dash light circuit.
The factory column used a fiber optic cable to light the shifter but the aftermarket may not. This is just a assumption I made from my desk here in Oregon. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
