Old 09-04-2021, 11:18 AM   #1
brandster
68 and 72 door question
I have a 72 truck and the driver side door is jacked up so I found a 68 door I can use instead.
I know the 72 door has the screw hole by the vent window and may use plastic clips instead of screws for the panels.
I also know the window crank sticks out further. My question is, are the window regulators/cranks interchangeable and also is there any other differences im missing? Thanks.
brandster is offline   Reply With Quote
Old 09-04-2021, 11:30 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 68 and 72 door question
Other than the hole the parts should carry over to the 68 door , Drill new holes for the door panel .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-04-2021, 11:33 AM   #3
brandster
Thanks!
