Old 09-28-2021, 09:01 PM   #1
Cris
Install of 292 Inline 6, How to Deal With Engine Mounts
I'm about to install a "refreshed" 292 into my 63 C10. I am looking for advice on how to deal with the engine mounts and perches. If I bolt the engine mount (with rubber) to the block and the perches to the frame, it looks like an almost impossible task to get the single bolt in that connects the two together as the engine is lowered. (That bolt is inserted from the bottom and you won't be able to see the alignment from the top.)
Do people bolt the mounts and perches together onto the engine before installation, then drop the engine in? At least then, you can see the holes in the frame to align the perches as the engine drops in. You could leave the bolts a little loose to allow some fudging room.
Looking for someone who has BTDT.
Thanks, Cris
Cris is offline   Reply With Quote
Old 09-28-2021, 09:39 PM   #2
geezer#99
geezer#99's Avatar
Re: Install of 292 Inline 6, How to Deal With Engine Mounts
For those bolts I’ve ground a 45 degree bevel on the end of the bolt. Clean the threads with a tiny file.
When you put it in the bolt will move enough to get thread engagement.
Kinda like the end on this bolt.
https://www.discounthondaparts.com/o...-seat-bolt-set
geezer#99 is online now   Reply With Quote
Old 09-29-2021, 12:41 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
Is your transmission still in the truck? I swapped engines without pulling the trans. Once the clutch splines lined up to the trans, the engine fell into place and was very easy to run the bolt from the frame stand to the rubber mount
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-29-2021, 02:12 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I installed new mounts on mine and reinstalled the perches on the engine and the frame mounts remained and the engine settled down and the holes lines right up. Worst case leave the hoist on the engine and lift it just a tad to see the bolts though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-30-2021, 02:20 PM   #5
Cris
Thanks guys, sounds like the consensus is bolt the frame perches to the frame, bolt the engine perches and the rubber mounts to the engine. Then drop engine in place. I'll leave the frame perches a little loose so position can be adjusted.
As TJ said, I'll leave the engine up a little off the frame perches to be able to see the alignment, then put the bolts in.
