Old 10-02-2021, 05:22 PM   #1
bigmac73
bigmac73's Avatar
aftermarket tranny x member opinions
I bought one of those "Performance" Square tubed x members from GMC Pauls for my transmission thinking it might be beneficial with my new 421SBC installation.
However sizing it up today for installation I find it is around 1/2 inch to short between the frame rails and the bolt holes do not line up, plus it is not centered for the tranny mount. It is a nice heavy piece however it does not quite match the pic on the website as well......
Now i am thinking of just putting a few welds on my factory x member to reinforce the rivets and then just painting and reinstalling. What do you guys think??
Any benefit over the stock piece for performance and strength????
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-02-2021, 07:34 PM   #2
AllGoNoShow
Re: aftermarket tranny x member opinions
Can't help you too much with the tranny crossmember. I took out an IFS (Ingenuity Fab and Speed) crossmember that worked well that the previous owner installed (they have been out of stock for a new one for a while now), and installed a TW Fab one which is remarkably beefy (and everything lined up perfectly).
What are the details on the 421 your building?! I've been kicking around that idea myself as well!
AllGoNoShow is offline   Reply With Quote
Old 10-02-2021, 07:45 PM   #3
jimijam00
See if GForce makes one for the C10. I got one of theirs in the Chevelle.
jimijam00 is offline   Reply With Quote
Old 10-02-2021, 07:55 PM   #4
bigmac73
bigmac73's Avatar
What are the details on the 421 your building?! I've been kicking around that idea myself as well![/QUOTE]
I bought a deluxe short-block from Nyes Racing in Muncie,In comes with a Dart SHP block, Eagle rotating assembly, SRP Pistons 10.5:1 , comp cam 237/246 520/530 lift with 113 LSA .
and I am waiting on a set of heads from Eric Weingartner out of oklahoma. His 195 profilers ported out to 213 CC .
I wanted to go down on the duration slightly around 233/241 and have a 112LSA but Pat McCreery said his cam grinder can not get roller cores. Normally they have Erson custom grinds. So he finally found me a on the shelf comp piece
Mike
Old 10-02-2021, 08:00 PM   #5
bigmac73
bigmac73's Avatar
if i google TW fab i get a hummer website???
Mike
Old 10-02-2021, 08:03 PM   #6
jimijam00
If you are lucky
Old 10-02-2021, 08:09 PM   #7
bigmac73
bigmac73's Avatar
G force does make them for a C10
Mike
Old 10-02-2021, 08:26 PM   #8
jimijam00
I'd buy it if I needed one for my C10. The one in my Chevelle fits like a glove and the 3" exhaust goes right through it.
Old 10-02-2021, 08:33 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Pull the rail in with a ratchet strap.
The oem frames are super flexible.
And move a bunch
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 10-03-2021, 01:43 AM   #10
AllGoNoShow
lol...Tin Works Fabrication...try that!
bigmac- whats the power output on that 421? Sounds great.
Old 10-03-2021, 07:40 AM   #11
bigmac73
bigmac73's Avatar
And move a bunch
i might try it.However I matched it up with my factory member and it is defiantly shorter.
Mike
Old 10-03-2021, 07:44 AM   #12
bigmac73
bigmac73's Avatar
I am shooting for 550 Torque, I told Pat i was not concerned about the HP . If you get the TQ numbers up the HP will follow suit. And I do not really plan on taking it higher that 5800RPM's
Mike
Old 10-03-2021, 10:57 AM   #13
68 P.O.S.
Have you talked to GMC Paul's about this? Confirm you got the right part?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-03-2021, 01:46 PM   #14
bigmac73
bigmac73's Avatar
No i have not this thing has been sittinf in my garage for about 6 month or.longer. i cant even find the receipt.
Mike
Old 10-09-2021, 11:36 AM   #15
bigmac73
bigmac73's Avatar
just found the receipt from Feb. out in the garage cleaning and going though a million parts boxes
going to give them a call and see what is up
Mike
Old 10-09-2021, 08:11 PM   #16
Davidf
I really like the Holley Blackheart crossmember
Davidf is offline   Reply With Quote
Old 10-15-2021, 10:21 AM   #17
bigmac73
bigmac73's Avatar
I will take a look
Mike
