Disc conversion questions
What to add disc brakes to my 1966 c20.
Found this thread 63-66 Crossmember Installed: 1) There are many advantage to leaving your 63-66 crossmember in place to add disc brakes. 2) 63-66 truck owners can now purchase "year specific" standard and drop spindles, from many aftermarket suspension vendors. * No need to change ball joints. * No need to change tie rod ends. * These new "conversion disc brake spindles" are a true "bolt-on" mod to add disc brakes to your truck. Summit racing has Classic Performance CP4S9 - Classic Performance Spindles disc conversion stock hight 1966 c20 year specific parts. Been looking at threads so far haven't found anybody that has tried these or something simalar. Any info would be greatly appreciated. Thanks |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Disc conversion questions
I kept mine. After driving around my new build I don't get why you need to change. I can see the torsion bar guys need, but...
![]() Join Date: Nov 2013
You mention you have a C20…do you want to keep the 8-lug wheels?
The spindle part number you quote is for a C10 and won’t work with your C20. I have first hand experience on my GMC with conversion spindles that work with 3/4 ton ball joints/tie rods but uses 1/2 ton brake parts. But I don’t know if that’s what you are trying to do. —Casey |
Thanks I'll double check
Guess I'm still looking for spindles Last edited by joecarquest; 10-06-2021 at 04:59 PM. |
![]() ![]() ![]() Join Date: Jan 2018
I haven't looked at the aftermarket companies for a disc spindle that works with the factory 63-66 ball joints and keeps the truck 8 lug.
If that spindle does exist, that's news to me. If it doesn't, your next best option is a stock spindle from a 71-72 or 73-91 3/4 ton, which looks like it requires the whole crossmember because of how the LCAs mount to the 63-66 arms
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Performance Online sells a C20 kit to keep 8 lugs on a 63-70 truck. I’d give them a call…
I've been looking for hours no spindle igsist that I found.
Thanks |
https://www.performanceonline.com/19...-8-Lug-Deluxe/
(Edited, I had the wrong link) This kit uses the Western Chassis spindles. You can use your original crossmember but it looks like you do have to swap out the ball joints and tie rod ends. I’ve found that both of my trucks needed these parts replaced anyway. |
