Old 10-08-2021, 11:16 AM   #1
bsarts
bsarts's Avatar
Parking Brake Cables
I'm having a hard time finding park brake cables for a 1962 K20. Does anybody have any info about the possibility that I might be able to use some cables from a later model truck? I've got a long cable running from the handle to a crossmember behind the cab with a fulcrum/lever set-up, then a shorter cable to each wheel.
Thanks, Brad
bsarts is offline   Reply With Quote
Old 10-08-2021, 04:46 PM   #2
72cs20
Re: Parking Brake Cables
Are your cables missing? Or do you just need new ones to replace the old ones?
The long one from the handle in the cab is available new. The two from the wheels can be made by a number of companies if you send in the old ones to be used as patterns. This is what I had to do for my K20. The company I used was Control Cables Inc.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 10-08-2021, 04:49 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Yes Control Cables Inc. has worked for a few people here.
Old 10-08-2021, 08:27 PM   #4
bsarts
bsarts's Avatar
Thanks guys, I'll give them a call.
Old 10-08-2021, 11:12 PM   #5
62K20
62K20's Avatar
Check out Inline tube. They make them in steel and in stainless steel. I used them on my 62 K20.
62K20 is offline   Reply With Quote
Old 10-08-2021, 11:39 PM   #6
JPBrecheisen
x2 on inline tube.
They've done all mine.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 10-09-2021, 10:55 AM   #7
bsarts
bsarts's Avatar
They are out of stock at Inline Tube, thanks though.
Old 10-09-2021, 08:59 PM   #8
JPBrecheisen
I had always sent them mine to copy. Maybe they don't offer that servoce anymore.
