12-03-2021, 12:09 AM | #1 |
Possible Quadrajet issue
Disclaimer, I haven't rebuilt a carb yet, but at some point I will
Anyways, of course, my Quadrajet carb book is back at home, so the answer might be in that, but I figured I would ask while I'm still here in Milly. On the vacuum port circled in red, I pulled the cap off and fuel spilled out It doesn't seem that fuel is coming out when the cap is on though. Also, when I put the cap back on, I noticed the port was a little bit loose and air bubbles formed around where the port goes into the carb body. Picture is from when I first put the carb on the engine over 3 years ago. Anyone seen that before? Have any advice? Thanks!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-03-2021, 01:10 AM | #2 |
Re: Possible Quadrajet issue
It’s a carb vent. Used to vent fumes.
Normally hooked to the charcoal canister with a long hose. If there’s fuel present it could be from from flooding or from the carb having fuel in the bowl and the carb being tilted forward. A secondary thought. The carb return spring should be Hooked rearward as low as possible back to the cable bracket. |
12-03-2021, 08:00 AM | #3 |
I put all my throttle springs toward the front. Putting them toward the rear looks more convenient but that is what wears the throttle shaft bushing.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
12-03-2021, 03:32 PM | #4 |
The driveway at my house in Milledgeville does have a bit of a slope down, so when I back in, the nose is definitely not flat. It's running good otherwise, so I'm hoping it's not flooding and that all it is is the parking angle.
On the return spring, I used the one from the old two barrel attached to the factory tab on the oil fill tube. It's been working nicely that way since I put this carb on
12-19-2021, 04:50 PM | #5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
