Old 12-20-2021, 09:36 PM   #1
Slammed96
Another 66 GMC! The Wonton.
Been bugging a buddy of mine about his grandfather's old farm truck for years and finally managed to save it! Plans for this one are not nearly as extravagant as my short wide. Really just want to get her running and use her as a solid work/shop truck. My goal is to get it running/driving for under $1000 then enjoy!
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop
66 GMC 1 ton stepside looooong bed- the tow pig/work truck.
Slammed96 is offline   Reply With Quote
Old 12-20-2021, 09:39 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Another 66 GMC! The Wonton.
Sweet! I love a nice long stepper
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 12-20-2021, 09:54 PM   #3
Slammed96
Got it into temporary storage and verified that the engine actually still spins over by hand, which is huge! Picked up a donor chassis to upgrade the brakes to disks, and also possibly swap over the rear end to have greater ease of finding replacement parts if need be. Not to mention a much more driving friendly gear ratio. I also picked up a carb for it off of a 63 C10 that also had a 250. Carb needs rebuilt, so that may be a winter project. Any suggestions on the best rebuild kits for these mono jet carbs?
Old 12-21-2021, 02:29 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Cool truck man.
Old 12-21-2021, 10:30 AM   #5
Slammed96
Originally Posted by The Rocknrod View Post
Cool truck man.
Thanks guys! Can't wait to have this out cruising in the hopefully near future.
Old 12-21-2021, 11:19 AM   #6
350TacoZilla
Looks to be a good truck to start with. I love the long steps after seeing them more in person leading up to me buying a 8ft stepside, it seem's like growing up all I would see were long bed fleetside and short bed steps.
350TacoZilla is offline   Reply With Quote
Old 07-16-2023, 10:09 AM   #7
Slammed96
Can finally start updating this thread! After sitting for a year or so at the in laws farm, we finally got the free time to go collect this beast and bring her home. From there it was immediate cleaning of all the field debris still in the truck. Followed by a quick assessment of just what all it really needed to be driving again.
Old 07-16-2023, 06:14 PM   #8
Slammed96
Found the receipt from the last time this old girl was registered and on the road. Also started putting many of my spare parts to good use. Swapped in a cluster that I had floating around, and also used a spare harness that was burnt up in another section to repair the rodent damage the truck had suffered while sitting in a field for the past 30 some odd years.
Old 07-17-2023, 10:22 AM   #9
Slammed96
Had a carb that I snagged shortly after initially buying the truck that I popped on the ensure it was right. Had to build a small portion of throttle linkage, as the original was missing. I did find the original air cleaner laying down in the engine bay, so mocked it up to see how it looked. Also snagged a new under hood harness from Classic Parts, as the original was more than somewhat crispy and beyond salvation. The original master cylinder was frozen solid, so I pulled it and swapped it for a Corvette manual dual master. Hopefully this works well with the disk brake swap I plan on doing.
Old 07-17-2023, 11:50 PM   #10
straight6chevyguy
straight6chevyguy's Avatar
Glad to see you back to work on this!
Cool truck.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 07-18-2023, 09:29 AM   #11
Slammed96
Cool truck.
Thanks! Really hope to have it driving by fall so I can have some fun with it.
Old 07-18-2023, 09:42 AM   #12
Slammed96
Got some more progress made on the truck. Once the wiring was all roughed in I hooked up a battery and did some functions testing. Everything appears to be working, and there was no smoke, so that's a good sign. A previous owner had an oil pressure gauge that they just cut out and left the line behind the dash. Found a cool vintage gauge set on marketplace for a reasonable price, so I went ahead and swapped that in. After an oil change and being cranked over, truck does build oil pressure. I did however find that I was not getting any spark. Also discovered that #3 is low on compression, I assume due to sticky rings.
