Old 02-12-2022, 02:02 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Problems with warm starts
Had this problem awhile back. My battery was bad and the problem went away after installing a new one about 6 months ago. I can take a 15 minute run to the parts house, go in ,get my parts , come right out and it just cranks. Usually
(cold) it fires with a touch of the key. After warm, Cycle the fuel pump a couple times and it reluctantly starts and needs to be cleared out to stay running. This is a 2002 LS1 with aftermarket harness. This is the only problem I’ve had with this since installing 2 years ago
HELP
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-12-2022, 08:38 AM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Problems with warm starts
A couple of things to check
1/ Bad cold grounds. I would be checking every ground wire connection by removing it and cleaning both the ground connector and the surface it mounts to.
2/ Heat soak into the starter from a set of headers too close to the starter.
3/ Bad battery cables causing a voltage drop. Check the cables for signs of corrosion and replace if necessary.
4/ Check the alternator output is around 13.8 volts or more.
Hope this helps
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 02-12-2022, 10:43 AM   #3
Davidf
Leaking fuel injector(s)? Check for fuel pressure bleed off. Crank, but stop before it fires…check for wet plug(s).
Davidf is offline   Reply With Quote
Old 02-12-2022, 12:52 PM   #4
1970 CST Short Wide
Senior Moment
Hope this helps
Theses are making good sense to check seeing that a new Battery seemed to solve last time this happened. Thanks
Pittsburg Ca
94565
Old 02-12-2022, 12:54 PM   #5
1970 CST Short Wide
Senior Moment
This was the first thing I looked at last time and even put a New set in with no improvement. Thanks
Pittsburg Ca
94565
Old 02-12-2022, 08:46 PM   #6
paul mora
Leaking fuel injectors
Pulatoy
paul mora is offline   Reply With Quote
Old 02-12-2022, 10:02 PM   #7
1970 CST Short Wide
Senior Moment
Pressure gauge holds a constant 58 lbs after shutting off
Pittsburg Ca
94565
