02-24-2022, 11:40 PM | #1 |
Daily drive lunch box locker
I need to replace the spider gears in my 8.5 but I was looking at maybe doing a locker instead. Specifically the Spartan lunch box style. This is for a daily driver. I don't go offroading. I go out in the woods in some mud and snow but I stay on a developed road unless of course I slide off. I do to a motorcycle trailer and car trailers sometimes and travel several hundred miles from home out in the high desert. So dependability is a must. As is driveability.
What experience do you guys have with this type of unit? I could also go the posi carrier route also. Little more work little more money but Better driveability. But I have also heard trucks are hard on them and wear out the clutches. This is a stock k1500 |
02-25-2022, 03:28 AM | #2 |
Re: Daily drive lunch box locker
A lunch box locker can be more harsh and noisy than a detroit or grizzly locker. Those type of lockers can be touchy on the street. Zero need for a LBL on the street. Low cost is only benefit IMO. I would use a torsen type diff like the Tru-trac if in your shoes. Strong, smooth and reliable, no clutches to wear out. Only drawback I have seen is it can act like an open diif when lifting a wheel. Applying brakes can help the problem but it does not seem like that would be a problem for you.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-25-2022, 08:35 AM | #3 |
Post Whore
Agree with Richard, im thinking you wont like it, buddy of mine tried one once, he said it was awful on the road
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-25-2022 at 08:49 PM. |
02-25-2022, 07:42 PM | #4 |
Sounds like a new set of spider gears are in order. I'm not going to put too much into this truck. Thanks for the input!
02-25-2022, 10:26 PM | #5 |
I would put a clutch type limited slip in it. The 30 spline 8.5” Yukon can be had for just about $300 if you shop around.
I believe everything should have an LSD or traction aid of some type. I run a Powertrax NoSlip in my CJ-5, and for a lunchbox it is surprisingly nice on the street, but they are expensive… I got two for the price of one so both ends of my Jeep are locked for 1/2 price. But I would NOT run a LockRight or a Spartan on the street. They are clunky and ratchety on the asphalt but near seamless off-road.
02-27-2022, 12:24 PM | #6 |
Had a K20 daily driver with 35's and a locker for 4yrs in all types of weather ( rain,snow and ice ) with no problems. It did make a clicking sound making tight turns, never had any loud clunking or any type of jerking with it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-27-2022, 02:32 PM | #7 |
People with heavier trucks seem to get along better with them. I had one in a ‘75 K20 up in AK for a few years and never really even noticed it. Guys with Jeeps seem to end up pulling them right back out and going with LSD’s or air lockers. Now that I’m thinking about it, maybe the shorter wheelbase makes it worse too. I dunno, just seems like a trend I’ve seen over the years.
08-16-2022, 07:32 PM | #8 | |
