Old 12-30-2003, 12:52 PM   #1
Heavy-Chevy
Exclamation Pop-a-top!!!!!!!
What is the best way to remove the top?
P.S. whithout breakage........
TRUCKS & Autos that run:
1972 GMC Sierra Grande 3/4ton LWB 4x4
1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit"
1988 K3500 Crew "Big Red" 4x4
PARTS OR PROJECT TRUCKS:
PARTS for sale or trade:
WANT :
1972 parts blazer/Jimmy parts truck
1967-72 Parts Chevy/GMC Truck
NEED stainless hubcap for 3/4ton GMC
Heavy-Chevy is offline   Reply With Quote
Old 12-30-2003, 12:59 PM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
unbolt it slide 2 2x4s under it bolt it to the 2x4 and have four people take it off. I usually just do it with two people and slide iti off the backe though. Make sure you have the tailgate open and watch bending the tailgate seal bracket.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 12-30-2003, 03:05 PM   #3
Paul72
Paul72's Avatar
I unbolt it and slide a 2X6 under bothe the front and rear. Tie a good quality rope (I use 550 cord) around each end of the 2X6 and thread thru a truss/hook/pulley attached to the garage ceiling. lift up on the top and pull down on the rope, securing the other end to the 2X6 also. Work your way around the 4 corners, doing a little at a time.
Hope this makes sense! a picture would be worth 1000 words here.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 12-30-2003, 04:34 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I think this link has the pictures for what Paul72 was describing.
http://coloradok5.com/topstorage.shtml
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-30-2003, 04:40 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I'll me a smart #ss and say use a 2x10.:p
The 2x4/2x6 is the right idea though.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-31-2003, 12:17 PM   #6
Heavy-Chevy
many thanks!!!!!!!!!!!
WANT :
Old 01-06-2004, 12:40 PM   #7
Grim Reaper
Re: Pop-a-top!!!!!!!
Ohhh Iwas going to make a smart comment after seeing a Jeep hard top all over I 75 this weekend but you wanted to use it again.
2x4's dont work if you have a full cage.
I have a retaining wall next to my house that's bed level. I wad up a packing blanket under the front of the roof so I can lift it from the back and slide it on the roll cage. Then I get under it and walk it off the truck on my back to waiting cinderblocks.
Bunch of wimps that can't get a LIGHTER 69-72 off by yourself when I do a 75 top a couple times a year.
If my truck fit in my garage I would rig a U shaped bracket to hook the sides of the top to lift it from.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 01-06-2004, 12:44 PM   #8
Heavy-Chevy
1985 top is lighter?
WANT :
Old 01-07-2004, 11:44 AM   #9
Grim Reaper
Yeah it's about 45lb lighter then a 73-75. Its about 30 inches shorter and no beefed area at the front. A 76-91 is around 160-175 dependining on the windows. 73-75 is around 230.
I know a 73-75 is heavier then a 69-72 single wall. Might be about the same as a double wall because of the flip up tail gate.
Grim-Reaper
Old 01-08-2004, 08:35 AM   #10
gmcnorton
gmcnorton's Avatar
help
it was alot of work but worth it. i welded a 6' x 6' steel angle frame ran cable down to 2 x 8 boards with quick release ends [ like the ones climbers use ] and a electric winch to pull it to the ceiling. tied it up secure just in case.
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 01-08-2004, 08:35 AM   #11
gmcnorton
gmcnorton's Avatar
sorry
can't attach pics???????
Old 01-08-2004, 01:18 PM   #12
Heavy-Chevy
Thanks Everybody!!!!!!!!!!!!
WANT :
