03-08-2022, 10:43 PM | #1 |
GMC grille letters
Maybe someone on here has tried this or knows the answer, but with the 66 GMC letters being stud mount, would the letters off of a 67-72 GMC fit the same? Or are they different size? Found a set of NOS letters advertised as 67+, but I honestly dont see much difference as far as just in the pictures.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
03-08-2022, 11:29 PM | #2 |
Re: GMC grille letters
If you have a part number from those NOS letters, you could search it on http://www.gmpartswiki.com/ and see if the numbers match
Maybe this will help: http://www.gmpartswiki.com/getpage?pageid=63048
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 03-08-2022 at 11:37 PM. |
03-09-2022, 07:33 AM | #3 | |
