03-21-2022, 03:31 PM | #1 |
Removing flat trim on bed?
I'm working on removing the flat stainless trim to peck out the dents in deformations from over the years in a tight garage. The cab and forward have nuts that I can access (although not easily) but there is no way to get to the back of the trim on the bed because of the inner sheet metal. How would I go about removing this stuff without stretching or damaging it?
Body man, I am not, however I can handle the dents in this SS. Thank you all in advance. |
03-21-2022, 03:46 PM | #2 |
Re: Removing flat trim on bed?
I believe the trim uses clips on the bed sides.
It's a slight challenge, but you can get your hand between the inner and outer sheet metal. Definitely much easier with the bedside off to reach up in between.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-21-2022, 09:00 PM | #3 |
You're exactly right. I just didn't look good enough.
Now I'll get out the band aids and go to work. Thank you. |
03-21-2022, 11:37 PM | #4 |
Happy to help! If you're doing it by yourself, maybe hang the trim with a couple pieces of tape so it doesn't fall off after all the clips are popped out.
