03-26-2022, 05:28 PM | #1 |
How to remove glass from door window ??
One of my window channels is really rotted, so I need to remove the glass to replace the channel, with a better one.
What is the best way to remove the glass. |
03-26-2022, 05:33 PM | #2 |
Re: How to remove glass from door window ??
Since the channel is already rusted, a slight pull apart might get the job done.
I remember it being fairly easy to pull mine apart when I was putting the new weatherstripping in. My passenger side had already come completely loose. I just had to pull apart the driver's side. The harder one was getting the vent glass out of the channel, but with some coaxing, they came out. I had a glass shop reinstall because I didn't have the setting tape and didn't want to break a piece while learning to put it back together
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-26-2022, 07:46 PM | #3 |
Here's a Brother's video on how to install all the glass in the door. Removal is just the opposite order. https://www.youtube.com/watch?v=fYA9pLr-ZlY&t=142s
03-26-2022, 08:56 PM | #4 | |
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
