05-03-2022, 10:04 PM | #1 |
6 lug to 5 lug
I have a 1972 with a 308 rearend and want to change to a 373 rearend. My neighbor has a 1970 6 lug 373 rearend and was wanting to know if I can take my 5 lug axles and put them in the 6 lug rearend.
Are the axle splines different? Is this possible and if so what concerns / issues will I run into? Both are 12 bolt rearend. Thank you for reading and thank you for taking your time to answer my questions. |
05-04-2022, 11:06 AM | #2 |
Re: 6 lug to 5 lug
The 5 lug axles are usually longer than most of the 65-70 6 lug axles. There were some 70 6 lug axles that were made in the same width as the 71-72 5 lug axles, but not very common to find those.
If swapping axles doesn't work, you can swap the carrier and r&p between the two
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-04-2022, 12:15 PM | #3 |
67-72 parts collector,…
Re: 6 lug to 5 lug
Every 6-lug 70 axle housing I’ve run across has been the same width as the 5-lug 71-72 housings.
Measure the two and if they are the same width, the axles can be swapped. I would look closely at your 5-lug axle bearing surfaces. This is a good time for new bearings and axles seals.
05-04-2022, 03:56 PM | #4 |
Re: 6 lug to 5 lug
Moser will cut fresh axles for you in any configuration you can afford.
05-04-2022, 04:15 PM | #5 |
Fabricate till you "puke"
Re: 6 lug to 5 lug
What Orange sunshine said.....I have Moser axles in my truck (75/12 bolt), & they were a stock item. I would bet that the axles you have will fit the early diff.....but if not you can measure & order the proper lenghts. It has been a few yrs back, but the axles were not that expensive (about $260 shipped, with studs). We all know that prices have gone up over the yrs....but also check other manufacters for prices....as said , many of the popular C-clip axles are , or were in stock. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-04-2022, 04:44 PM | #6 |
Re: 6 lug to 5 lug
When I rebuilt the 12-Bolt differential from my '67 K/10 Suburban, the GM plant that made them was on strike. New OEM axles were unavailable. The diff shop said, try Moser.
I called them, and they were able to cut me a new pair for the same money as stock. When they came in, I was concerned that the outside diameter of the flange that mounts the wheel studs was over an inch smaller. Moser said they were guaranteed for life. That rearend, with an added Auburn posi served under the Sub for about 3 years. Then an engine fire [and being Totalled with a Salvage Title by the insurance company] grounded the Sub. In 2010, the 12-Bolt 3.73 Eaton posi under my '71 Jimmy lunched out. We cannibalized the Sub's diff for the Jimmy. Still running good for 12 years.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-04-2022 at 04:46 PM. Reason: onm |
05-11-2022, 03:51 PM | #7 | ||
"I ain't nobody, dork."
Re: 6 lug to 5 lug
Moser has 5-lug "replacement" axles you can buy that fit the narrower 6-lug housings. I put a set in a 1969 12 bolt housings and they worked perfect.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-12-2022, 05:32 PM | #8 |
Re: 6 lug to 5 lug
I have a 70 diff 3.07 or 3.08 in my 66 C10 and the axles are wider so I think you are good to go with what you want to do.
