62 front shocks
The front shocks on my 62 c10 need replaced. I have a couple questions for the board.
1. How do you tell if the truck has been lowered from a stock 62? I think it may have been lowered just in the front and possibly by adjusting the torsion bars. Where can I measure from or get the stock layout to check. 2. If the truck has been lowered will a stock front shock still work or do I need to measure from a specific point to determine shock replacement length. 3. Best shock for this application? I can afford decent quality 125-150$ range per. I think I would be better off if I were to swap crossmember to a later model but right now I’m living out of an rv til the house and shop get rebuilt so I don’t want to tear it down too much til then and I get to replacing some tools. The driveway is uphill so the trucks stance isn’t quite as apparent here as when on flat ground. |
Re: 62 front shocks
Just adding a picture of the current L front shock as viewed from the rear.
Re: 62 front shocks
You will be fine with a stock shock.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: 62 front shocks
Get us a picture of the torsion bar adjustment bolt.
If it's been lowered, depending on how far, they'll be sticking down a ways. Otherwise, they should be tucked up within the crossmember. . . Look at page 2 of this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=472091. . .
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
