06-12-2022, 03:26 PM | #1 |
Speedometer 5 mph off
71/C10 350/350 trans has gray gear on the cable, what color gear do I need to change to?
Speedometer reads 50 mph when going 55 mph Thanxs
Things happen for a reason! |
06-12-2022, 03:43 PM | #2 |
Re: Speedometer 5 mph off
There are calculators online.
You put in tire size, axle ratio and drive teeth. Scroll down in the links below and both have calculators. The second one explains the tire stuff better. Link: https://transmissioncenter.net/shop/...ar-calculator/ Link: https://www.tciauto.com/speedometer-gear-calculator
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
06-12-2022, 06:52 PM | #3 |
It is not off 5 mph, it is off 10%. So you need to speed up the cable by that amount
06-12-2022, 07:08 PM | #4 |
According to my notes, each tooth on the driven gear on the speedo cable changes the ratio by roughly 5%. After swapping to a 700R4 with 3.42 gears, my speedo reading was about 15% higher than actual, so I needed a driven gear with 3 more teeth to reduce the speedo reading. My driven gear was also gray (22 teeth). Check my findings, but seems like you might need a driven gear with 2 less teeth to increase your MPH reading (5MPH/55MPH=~9%). The OEM GM 20-tooth gear is blue, 21-tooth is red.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
06-12-2022, 07:46 PM | #5 |
06-12-2022, 08:33 PM | #6 |
Thanxs guys,that's just what I needed..... the 20 tooth gear should fix my issue.
06-12-2022, 10:35 PM | #7 |
Keep us Posted on results.
This will help the next guy
06-13-2022, 10:01 AM | #8 |
FWIW, same issue with me. I had a 21 tooth in my spare parts which got it closer. Bought the Blue 20 tooth but no work. Seemed like the drive gear was not engaging with the 20 tooth. IDK what drive gear my 3 speed Saginaw has (8??). 20 tooth should work (GM blue gear) but for some reason for me it didn't. Ideally your trans is happy with a 20
06-13-2022, 10:40 AM | #9 |
Maybe the diameter sizes will help with understanding the speedometer issues.
Here is an example of the challenges; If you measure the diameter of the gear, a new one is 0.81". It is designed to be used with only a 1.84" diameter drive gear. You installed a green 22T driven gear. A new green 22T gear has a diameter of 0.87". This gear is designed to be used with a 1.74" diameter drive gear. If drive gear in your transmission is 1.74" diameter. You cannot use the smaller diameter driven gears in the current transmission configuration. The gears do not mesh (teeth do not touch). green 22T driven gear (0.87" diameter)---- 1.74" diameter drive gear red 21 T driven gear (0.81" diameter)---- 1.84" diameter drive gear Also, if you try the other way (0.87" driven, 1.84" drive), the plastic driven gear will be destroyed after a short while. Exactly why this is so complicated. To make this worse you can have the same drive gear (on the transmission output shaft) with the same tooth count in two different diameters. GM made is easier in later years but that's a different story/post. I have included a picture that indicates how to count the teeth on the drive gear by viewing it on the side. This is an eight tooth gear. Cheers Last edited by Accelo; 06-13-2022 at 10:46 AM. |
06-13-2022, 01:35 PM | #10 |
Post Whore
Good explanation.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-14-2022, 05:18 PM | #11 |
why does there have to be math?
I got a bench seat baby, you don't have to sit over there. |
06-14-2022, 06:06 PM | #12 |
06-14-2022, 06:11 PM | #13 |
The link I sent above is for an External option.
There was (years ago) A box with gears you could change out, That connected to the Transmission, and you hooked up the speedometer cable on the side of it. That is probably what they offer? IDK
06-14-2022, 07:06 PM | #14 |
In this artcile from Chevy Hardcore they say each tooth is 3mph.
https://www.chevyhardcore.com/tech-s...to-correct-it/
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
06-14-2022, 08:55 PM | #15 |
There was (years ago) A box with gears you could change out".
You still can purchase the conversion boxes. You will spend $125 to $150 to get one configured correctly. You can get them for 1/2 that on Ebay but finding the correct ratio isn't easy and you have to do the math either way. |
06-14-2022, 09:07 PM | #16 |
Don't you remember your middle school teacher telling you that you would use math the rest of your life?
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
06-15-2022, 10:40 AM | #17 |
I've been watching this thread with keen interest as my speedo is about 10% off as well. When I had the gear and everything out last winter I am almost certain it was the gray one and I have a blue one on order now.
Oh yeah, as I told my wife once: "Your whole world is bounded by math. With the correct equation, I can predict almost anything." But, I am an egg head engineer so it's a day at the office for me.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-17-2022, 04:53 PM | #18 |
Well I looked through my parts drawers and found a lite beige colored gear with 19 teeth, I installed it and added a lil tranny fluid cause of the mess I made but any how, we left and went on vacation so I haven't got to drive it yet. Will tell yall how it goes as soon as I get back home.lol
