06-22-2022, 02:33 AM | #1 |
Rear Wheel width
What is the widest wheel you can fit on the back. I’m lowered 6in in the rear I found a set of wheels on Facebook market place and thought 20.10.5 would work.
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
06-22-2022, 12:48 PM | #2 | ||
"I ain't nobody, dork."
Re: Rear Wheel width
You can go fairly wide with the correct offset.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-22-2022, 03:22 PM | #3 |
4.5 bs you can fit a 295 on a 10" wheel.. that's max for a 1968 anyway..
i know the later years had a different width rear end. |
06-22-2022, 04:01 PM | #4 |
Post Whore
You need to verify which axle width to be sure of the back spacing needed.
Since you are lowered you will need to have a long adjustable track bar installed to center the axle at ride height. Good luck with your purchase. If they're local drive over and do a test fit.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-22-2022, 09:24 PM | #5 |
Fleetside or stepside?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
06-23-2022, 07:14 AM | #6 |
If it is not lowered, 12" is possible but very tight. If it is lowered, then 10" is probably max. The inner fender arc is pretty fast, so when you lower it, and assuming you give it 2-3" of float, your wheel will have to not be as wide.
I installed 2" wider tubs. You don't really even notice the extra width like you do on the 4" wider versions. With that, my actual tire width is 13.8". |
06-23-2022, 07:35 AM | #7 |
06-23-2022, 11:10 AM | #8 |
As mentioned, the first thing you want to check is what Rear end housing is in the truck now. 63 (earlier?) - late 70, these trucks had a slightly more narrow housing in them than the later years. The only real way to know is to measure it. 5 or 6 lug doesn't really tell you much. It may have been swapped at some point in its life (?) Just saying I'd measure it.
The easiest way I know to do it, is just lay under the back of the truck. Have your wife, buddy, whatever hold one end of the tape against the back side of the rear brake backing plate. (Assuming drums on the back?) Measure across to the other side in the same spot. If it's roughly 57", you have a later rear end housing. If it's 55.5", it's an early housing. So, with this in mind the rear housing width can make .75" difference per side, and if the truck is really low it could mean the wheels fit, or.. they don't. Not all the trucks are the same and if you don't have an adjustable track bar on it, I too would suggest one. It will even up the axle housing side to side. That way you're not rubbing on one side, and 2" clearance on the other. We just need to know which housing you have, and I can make some suggestions for you from there.
06-23-2022, 11:16 AM | #9 |
11"maxium on (stock setup Frame/wheelwell) with aftermarket wheels.
fitting inside the wheelwell. |
06-23-2022, 03:14 PM | #10 |
I have enclosed some pictures of 275/45R20 on the rear of the 1970 truck that is lowered 4 or 5". Wheels are 10 X20's and have zero offset. I don't see how one could go any wider, with stock wheel wells, without some issues.
Certainly no room on the inside. The outside may have a little room but that would depend on the profile of the tire and how low you are. Last edited by Accelo; 06-23-2022 at 03:29 PM. |
06-23-2022, 06:41 PM | #11 |
This is what we are doing for a little bit more room.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
06-23-2022, 10:51 PM | #12 |
That sir, is some really nice metal work.
06-24-2022, 07:05 AM | #13 |
06-24-2022, 07:48 AM | #14 |
That’s what we figured about an inch gained. On a blazer there’s not much room between the rear seat and the wheel tubs so I don’t have a lot of options to run a wider tire. My fabricator is pretty good though he did those way better than I had anticipated.
