08-03-2022, 09:23 AM | #1 |
worn yoke
Getting ready to pull the motor and trans for rebuild and found this wear spot when I dropped the driveline. When I drained the transmission there was maybe 8 oz of fluid might have been ATF. It was wet around the yoke. Wear doesnt go all the way around mostly just that flat spot .Would you run this or replace? Could use a source to replace. Thanks
08-03-2022, 09:36 AM | #2 |
Re: worn yoke
I'd definitely be replacing that. What transmission are you running?
08-03-2022, 09:52 AM | #3 |
Re: worn yoke
08-03-2022, 02:53 PM | #4 |
Re: worn yoke
Positively replace it. I'd also replace the extension housing bushing as it is no doubt pretty well worn out.
08-03-2022, 04:37 PM | #5 |
Re: worn yoke
08-03-2022, 08:24 PM | #6 |
Re: worn yoke
It should be a pretty standard item.
