08-05-2022, 11:43 AM | #1 |
'67 C10 Raising bed floor 2"
Hey guys.
I've come to the conclusion I need to raise my bed floor. I have been running no floor for a couple years, because I'm slow when I do things and it gave me a chance to monitor all the work I was doing on the back half of the truck. I have a wood floor that needs to go in. Realistically my 9" housing would have probably hit the floor at some point, so I put bump stops in to limit this but now I'm hitting the stops on big bumps. I do not want to go higher on ride height. Is there an "easy" way to do this? I would do 1/2", 1". 2" whatever if theres a certain amount you can go before really crossing the bridge and building framework for everything to go up. I'm just really close and anything would help me out. I don't necessarily plan on going any lower in the future. I assume my flange around the outside of the bed would need to be cut off and welded up higher where it bolts the bedsides to the wood slats. I am also guessing the tubs need to be cut shorter and the flange moved up on them as well. Any insight would be extremely appreciated. Thanks in advance! |
08-05-2022, 03:03 PM | #2 |
Post Whore
Re: '67 C10 Raising bed floor 2"
The only advice I would have would be to ask a moderator to move your thread to the pickup section. I am assuming you have a pickup as I just can't imagine driving a Burban with the wood floor removed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-05-2022, 11:53 PM | #3 |
The Older Generation
Moved to pickup forum. LockDoc
08-06-2022, 09:23 AM | #4 | |
Ah shoot!!! I'm really sorry about that. Thanks for the heads up! Thank you LockDoc, sorry about that. |
08-06-2022, 10:01 AM | #5 | |
LockDoc
08-06-2022, 10:34 AM | #6 |
Member cab4word67 raised his bed not too long ago. He might have some suggestions for you. His was a stepside though.
http://67-72chevytrucks.com/vboard/s...postcount=2775 |
08-07-2022, 02:47 PM | #7 |
Since I'm in the middle of replacing my wood bed on a 8' Fleetside box. to raise the floor only, you could use 2" square tubing or c channel and attach it to the sides, shim up the cross pieces and then install the wood and strips to the furring. Probably could use wood also and longer bolts. Sounds like a lot of work. What about just a raised portion at the axle. Of course you loose some truck functionality, but I'm assuming you have lowered it and don't use it as a truck now. Good luck
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
08-07-2022, 04:52 PM | #8 |
BlahBlahBlah
hewittca raised his bed in a pretty cool way, maybe you could do something similar but like you were saying, only a couple of inches.
https://67-72chevytrucks.com/vboard/...=821012&page=3
08-08-2022, 07:56 AM | #9 | |||
(Disregard frame in foreground of picture below, garage is too packed full of junk.) This is my current ride height though.
I also wanted to note I'm going to hinge the whole center section so that throws a wrench in a couple things as well but hopefully shouldn't be bad. I'm slow, but still working on the hinge mechanism (pictured below). I will use a double bear claw latch with release to latch the back down, giving me access to my tank, pump, suspension components and vent canisters. Quote:
It's actually still used as a "truck" if needed, which is why it doesn't have nice shiny paint on it for the time being. Quote:
Alright that wins. That's probably the most correct way to do it, and good for him on a job well done. He addressed several other modifications I am needing to do as well. Thank you very much for this. |
08-08-2022, 08:33 AM | #10 |
I'm glad you like my method and it can help out It is a combination and variation of several different methods that I've seen done before. My approach was all centered around retaining the ability to still load up the bed occasionally and actually use it as a truck. The truck is not drivable yet, but I do have the bed loaded up with all my extra parts and there's still plenty of suspension travel left.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
08-08-2022, 08:40 AM | #11 | |
I'm a sucker for wanting things to be unnoticeable to people that anything was ever modified and maintaining factory characteristics. Yours looks really clean. I need to read over that thread a couple more times before I ask any questions in case I missed something though. |
08-08-2022, 02:31 PM | #12 |
what if you bolted bed sides to the bottom of crossmember,(instead of top),
and installed new floor on top of cross member ? that would give you about 1.5" drop? |
08-08-2022, 02:35 PM | #13 |
You might be on to something. Then just space up the cross members 1.5" also so the whole bedsides aren't down 1.5". I'll look at it again tonight.
