Old 08-15-2022, 09:22 AM   #1
GSP7
GSP7's Avatar
81 K20 Thermostate 160
anyone using a 160 thermostate
81 k20, hot weather SW desert truck, aint running a stat presently, moving to PNW
Any preference on the Rock Auto , 'standard, performance, heavy duty, premium' choices?
Im thinking 'standard replacment'
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 08-15-2022, 03:20 PM   #2
MySons68C20
MySons68C20's Avatar
Re: 81 K20 Thermostate 160
Standard replacement should be fine but I would run at least a 180 deg stat.
The engine wears more if you run it to cold.
I'm dating myself here but Smokey Yunick did a study or article years ago showing the different wear characteristics on the diff stats.
The only advantage to using a cooler stat is cooler denser air for slightly more power.
My .02 cents.
MySons68C20 is offline   Reply With Quote
Old 08-15-2022, 10:49 PM   #3
Mike C
Mike C's Avatar
I would also run a 180 T-stat. I prefer the Robertshaw high flow “edge seal” thermostats.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-16-2022, 12:25 AM   #4
GSP7
GSP7's Avatar
I picked up the Johnson High-perf. turbo swirl thermostat
