Old 08-27-2022, 05:26 PM   #1
speedwrench44
Help: 67 Burb w/L83 cruise control
67 suburban with 2015 L83 engine, stock ecu, 2002 4L60 trans w/TCI EZ-TCU controller. Dakota Digital cruise control. Not able to get the cruise control to work without surging/hunting
DD has suggested setting the long term and short tern fuel trim temps to 50* and lowering the sensitivity in the throttle pedal. Neither has cured the surge problem. CC works thru the ecu except it picks up speed signal from EZ-TCU.
Set at 60mph it slowly drops off to around 57 then unlocks converter and accelerates to about 64, then slowly drops back off. Each surge cycle lasts about 20-30 seconds
Anyone have any suggestions?
speedwrench44 is offline   Reply With Quote
Old 08-27-2022, 06:45 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help: 67 Burb w/L83 cruise control
I will move this to the LSx Swaps forum. I think you will get more responses there....
LockDoc, Moderator
Leon
Old 08-28-2022, 12:09 PM   #3
speedwrench44
Thanx
