10-03-2022, 06:24 PM | #1 |
6 lug rotors
Hi all
Will 88-98 6 lug light duty 3/4 ton rotors fit on my 72 c20 disc brake spindles? My brakes are toast and would like to upgrade To this if possible. |
10-03-2022, 10:47 PM | #2 | |
The Older Generation
Re: 6 lug rotors
You can look through Keith's brake conversion thread and see what you can find.... http://67-72chevytrucks.com/vboard/s...d.php?t=456889 LockDoc
10-03-2022, 11:17 PM | #3 | |
67-72 parts collector,…
Re: 6 lug rotors
Some have used the 88-98 light duty rotor AND spindle by changing to 88-98 balljoints in your c20 control arms. I can’t remember which outer tie rod to use. BUT,… the end result was too much positive camber to get the alignment back into specs. The EASIEST way to convert to 6-lug from a c20 is to swap lower control arms to a c10 version and use c10 spindles with aftermarket 6-lug rotors. (Or 5-lug rotors) This has been done for years and has been proven to work.
