Old 01-04-2004, 01:30 PM   #1
kiley
Towing an Airstream
I'm about to get a '78 31 foot Airstream travel trailer. I'm concerned about towing. I'll be going through mountain passes alot. I currently am set up with 33" tires and 3.73 gears, fairly stock 350 and th350. Should I be concerned about going to different gears? A 383 will be in the future so should I just get by until then?
I'm about to install ARB air lockers in the front and rear and don't want to do it twice.
Thanks for your input.
kiley is offline   Reply With Quote
Old 01-04-2004, 07:21 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You should definately get a transmission cooler if you don't have one. I would also look into rear helper springs. That's a lot of trailer to pull with a Blazer.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-04-2004, 08:20 PM   #3
kiley
I've got a transmission cooler, forgot to mention that. My dad used to pull it with a 79 Blazer but it had a small block 400 in it. I don't remember what the gear ratio was but that blazer was bone stock except for the trailer brake stuff. He has pulled that same trailer with 3 other 1/2 ton suburbans just fine but again i don't remember gear ratios.
Old 01-05-2004, 12:50 AM   #4
bouncytruck
SKINNY TIRES RULE!
My opinion is that the 3.73's should be ok. The problem with the Blazer is going to be the short wheel base. That trailer may pull the truck around a little.
bouncytruck 1972 K5
Old 01-05-2004, 01:52 AM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
The wheel base of the K5 is my concern to. I'd highly recommend a trailer sway control bar and some load lever bars. I pull a 25' trailer with my 1 ton extended cab truck and they make a world of difference. That trailer is one of the heaviest trailers made. They're awesome though. If that trailer ever started to wipe on ya it would try and flip that K5. I don't recommend it.
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 01-05-2004, 01:53 PM   #6
bouncytruck
SKINNY TIRES RULE!
What is the weight of the Airstream anyway? They are very nice trailers and becoming quite the collectors items these days. One of the girls in my office is really into them, like we are into Blazers. She watches the Airstream sites like we watch these boards.
http://www.airstream.net/
http://www.airstreamcentral.com/
http://www.airstream-bohemia.com/
and the list goes on...
bouncytruck 1972 K5
Old 01-05-2004, 07:09 PM   #7
kiley
weight and sway bars
Dad told me the trailer is 3 tons empty. We have the sway bar setup. The short wheelbase concerns me a little but we always did so well pulling it with dad's 78 k5 that I think I'll be ok. Of course the speed limit back in the late 70's and early 80's was 55 so in today's world of 65+ it might not do so well. I Oregon you are hard pressed to do more than 60 unless you're on I-5.
Old 01-05-2004, 07:10 PM   #8
kiley
bouncytruck
Thanks for your replies. I remember seeing you on ColoradoK5.com alot.
Old 01-05-2004, 08:24 PM   #9
mister.freeze
mister.freeze's Avatar
MY '72 K5 HAD A 454 WITH A TH350 AND 373 GEARS TO PULL A 42'YACHT AROUND IDAHO. BOUGHT IT WITH A 350 AND PUT IN A 383. DON'T WORRY ABOUT YOUR GEARS OR TRANS. AS LONG AS YOUR 350 HAS GOOD COMPRESSION, YOU'LL BE FINE.
mister.freeze is offline   Reply With Quote
Old 01-05-2004, 08:28 PM   #10
kiley
wheel base
Did you ever have issues in towing because of the short wheebase? How did the 383 do towing the Yacht?
