11-08-2022, 05:13 PM | #1 |
Sanderson Header Owners
I just ordered a set of Sanderson BB8 headers for the 454 in my '72 Suburban. My question is regarding their claim that "No Gaskets Are Required...only Permatex Black High Heat Silicone"? My exhaust guy says he has never NOT used gaskets, even with Sanderson's, so I'm asking what has been your experiences...any issues without gaskets and for how long? Thanks for any insight you choose to give!
Woody |
11-08-2022, 05:38 PM | #2 |
Re: Sanderson Header Owners
I have Sanderson headers on my LS swapped 98 Wrangler. I used good Fel Pro gaskets. They have been bullet proof for over 14 years. Zero leaks.
11-08-2022, 05:50 PM | #3 |
I know Sanderson claims that. They have thick flange....IMHO I would and do always use a gasket, Felpro but do not have Sanderson headers
If your heads are dead nuts perfect and aluminum (read not cast iron), go for it...but I would use a gasket with that said my 67 327 stock manifolds did not have gaskets and never leaked. YMMV |
11-08-2022, 07:12 PM | #4 |
Fellow 454 owner with ceramic coated Sanderson headers here. I am running aluminum crush gaskets simply because I had them prior to purchasing/installing headers. 72SB makes a good point, if your heads are aluminum and perfect you could run them as Sanderson suggests but I believe you will find most run them with a gasket. Also, if for any reason you ever need to remove the headers/exhaust system, a gasket makes the job much easier. I drive my rig daily and very hard. These headers have performed flawlessly, the finish is holding up very well despite the dusty gravel roads I drive on and badly worn valve guide seals. I'm using the header bolts provided by Sanderson (non-locking). I check them every oil change and so far (12K) no need to tighten them.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
11-09-2022, 02:09 PM | #5 |
I have Sanderson SBC headers with no gasket and iron heads; used Black Permatex as suggested no problems for 5 years.
11-09-2022, 03:06 PM | #6 |
11-09-2022, 03:21 PM | #7 | |
Woody |
11-09-2022, 03:28 PM | #8 | |
Woody |
11-09-2022, 03:34 PM | #9 | |
Woody |
11-09-2022, 09:37 PM | #10 |
As a tech who has been in the trade for at least 25 years, i rarely use gaskets when installing a manifold on a vehicle. I actually have more issues with gaskets blowing out than silicone. Most headers do not have a thick mounting flange but it appears that sanderson does, if they recommend it i wouldn't hesitate doing it!
11-10-2022, 12:03 PM | #11 | |
Woody |
11-12-2022, 12:57 AM | #12 |
Put a set on with good Cooper gaskets and leaked….took gaskets out and no leaks …best headers I ever bought!
11-13-2022, 02:21 PM | #13 | |
Woody |
11-13-2022, 05:47 PM | #14 |
I have never mounted headers without gaskets but all the fords with manifolds I have worked on have been installled with a layer of bearing grease. Never had a problem doing it that way.
11-15-2022, 11:21 AM | #15 |
11-15-2022, 11:50 AM | #16 |
Thanks to all for the insights you have offered-up! I guess I'm going to let my exhaust guy do it his way (with gaskets) as I've already bought the gasket set he requested (Remflex) although I also bought some Permatex Black just in case he wants to experiment (doubtful)! With these Sanderson headers, it doesn't seem like it's going to be an issue either way!
Woody |
