12-21-2022, 04:13 PM | #1 |
Rear tire 20inch fitment ?
Will a 275/40/20 tire fit the rear of my fleetside, it has been lowered 4 inches
4.75 inch backspace 28.7 inch diameter, If not, what is a good size for a 20 inch wheel in the rear. Last edited by kens65fb; 12-21-2022 at 05:31 PM. |
12-21-2022, 08:56 PM | #2 |
Re: Rear tire 20inch fitment ?
Stock 12 bolt or slightly wider axle from a later year truck?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-22-2022, 08:44 AM | #3 |
12-22-2022, 10:30 AM | #4 |
There's never an exact answer for these questions. What fits on 5 different trucks might have issues on 5 other trucks because of subtle variances. What's the BS on the 15's?
If the wheels are the same width & BS, only the height is slightly different. At only 4" of rear drop, that change shouldn't be an issue. There can be minor size variances between similar section width tires (275mm), especially when using different diameter combos w/different aspect ratios (40 vs 60). It comes down to where the new combo will sit relative to where the old was & the amount of clearance the old combo has.
12-24-2022, 10:11 AM | #5 | |
12-24-2022, 01:14 PM | #6 |
It shouldn't @ only 4" of drop.
To 100% verify, set the truck up w/some jack stands so the rear end is compressed/has weight on it but off the ground. Tape some 2x4 blocks to the tire/s, spin the wheels/tires & see what happens.
01-01-2023, 09:05 AM | #7 |
Just here to tinker
I use this tire calculator quite a bit when trying to decide on wheels/tires. It’s nice because you can enter your existing tire size and then compare to the new one. Just an idea to help you out.
https://tiresize.com/comparison/
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
