01-04-2023, 12:33 PM | #1 |
WTB Boyds Tank & aftermarket crossmembers
Like the title says, I'm in the market for a few things before I pull the trigger on new or direct from the source I figured I'd see if anyone has something they'd look to sell. Looking for a boyds tank for my c10, EFI or non, can make either work. Also looking for aftermarket crossmembers while I'm going though my frame & suspension. Ben looking at a new trailing arm crossmember, trans crossmember, core support, and rear frame crossmember. Been looking at Tinworks, porterbuilt, no limit, and react, but open to see what anyone has. Would need shipped to 20151 (business address) if meeting up is not feasible, thank you.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
01-06-2023, 03:32 PM | #2 |
Re: WTB Boyds Tank & aftermarket crossmembers
Bump for the weekend!
01-06-2023, 05:39 PM | #3 |
Pm sent
01-09-2023, 12:22 PM | #4 |
I have a NewInBox POL/Holley/Brothers transmission crossmember available.
Not that far from you - D.C. area. PM if interested. https://www.holley.com/products/driv.../parts/TCM6372 I got this because it was lighter, leaner, cleaner and more versatile than the original, and it offers more strength/support than the other aftermarket options as it has 3 sides and effectively "boxes" the frame rail and bolts top and bottom, versus others having one side bolting to the bottom of the frame rail. |
