01-18-2023, 03:55 PM | #1 |
Classic performance parts steering wheel crooked
Does your gear selection indicator sit at 12:00? I just installed my CPP column and my indicator is sitting at 12:30. The notch in the steering column shaft that sits over the protruding notch in the brake pedal steering column mount housing, those notches don't line up centered between the shift indicator screws. Are everyone's shift indicators slanted to the right?
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James |
01-18-2023, 09:39 PM | #2 |
Re: Classic performance parts steering wheel crooked
Wow that’s hard to look at
01-19-2023, 09:00 AM | #3 |
I feel like I'm eating a taco
01-19-2023, 09:49 AM | #4 |
Post Whore
Yep, that's cockeyed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-19-2023, 11:28 AM | #5 |
Just out of curiosity, what does it look like on the other side of the firewall at the bracket?
01-21-2023, 11:24 AM | #6 |
Here's the engine bay side
01-21-2023, 07:20 PM | #7 |
It should be straight up at 12:00
The rectangular holes in the column tube should line up with it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-22-2023, 09:04 AM | #8 |
I called CPP and they say they are looking at their columns to see if there is a problem. I called IDIDIT and they said their columns don't have this problem because the user drills the shift indicator holes themselves. I called local IDIDIT reseller and he says he cuts the brake housing nipple off to make the CPP columns straight. I'm not doing that. I imagine I'll get a replacement CPP column or I return it and get an IDIDIT column.
This has been a ton of work and hassle with the issues with the CPP column. I feel like they owe me $500 in labor costs.
01-23-2023, 04:34 PM | #9 |
I have been looking at the CPP tilt column due to the price and their saying it is all new. The shift indicator lining up right is one of the reasons I would want to change out my current stock column. Did CPP ever get back to you? Sounds like paying the bigger money and going with IDIDIT is the way to go for me.
1970 GMC C1500 short fleet Sellers Regret - 1950 GMC - 1967 Chevy C10 - 1970 GMC C2500 Dually Flat Bed - 2003 Silverado |
01-23-2023, 08:03 PM | #10 |
I was going to say loosen the column clamps on the firewall and under the dash and rotate the column counter clockwise, but that would put the shifter in an odd angle. Looks like that column you have is actually defective.
I have seen the IDIDIT units and they look really nice...or get a used GM tilt column and refurbish it. |
01-23-2023, 09:55 PM | #11 | |
01-23-2023, 09:57 PM | #12 | |
01-27-2023, 12:33 AM | #13 |
hum. its odd indeed. Perhaps your signiture might explain something about the fit:
1971 GMC C10 cab. 71-72 Chevy grill. Maybe a 77-78 K10 frame. Long bed cut to short bed step side. Manual changed over to automatic R700 4 speed It seems your truck has had a LOT of work. Perhaps this is not a CPP issue. hum
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
01-27-2023, 09:12 AM | #14 | |
01-27-2023, 09:33 AM | #15 |
Column fitment only involves the cab and all columns interchange in 67-72 trucks
01-27-2023, 10:48 AM | #16 | |
01-27-2023, 12:57 PM | #17 |
subscribed
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
01-31-2023, 07:20 PM | #18 |
CPP is claiming that all C10 trucks have offset gear selection indicators
01-31-2023, 09:55 PM | #19 |
Now that’s funny I’d tell them the experts in this truck club are seeing this and all potential customers
01-31-2023, 10:27 PM | #20 |
Tilt column I got here from Don D lined up perfectly. No issues
01-31-2023, 10:54 PM | #21 |
Here is the nipple I was referring to.
02-01-2023, 08:33 AM | #22 |
I need some pictures to show the CPP representative that the indicator housing should be centered. Could you all post some pictures in this thread?
02-01-2023, 09:40 AM | #23 |
I'd tell Moises Perez to let me talk to your QC Dept. so they can convince me as easily as they convinced you, with a poor and incorrect answer! Oh but wait, the customer in the store confirmed it. My bad. The thousands of people who think the indicator should sit square, based on the view from the driver seat or their truck, are wrong. Or, maybe he should have asked that customer if his column was a CPP as well.
02-01-2023, 12:32 PM | #24 |
CPP doesn't give a damn. My dealings with them were similar, they will do anything but admit their parts are poorly designed..
02-01-2023, 05:50 PM | #25 |
Ahh I see. Now I gotta look at mine. Assuming the support/brace would have the nipple regardless if automatic or clutch truck.
Maybe a longshot but I think I saw in a previous post your dash was bent. Would that play into this at all? Just a thot?
