03-26-2023, 05:44 PM | #1 |
Advice needed on a-arm rebuild
So we are rebuilding the upper and lower control arms on our C20, replacing both the ball joints and crossshafts in all the arms. Got the uppers put back together without to much issues. Torqued the 4 ball joint bolts to 15ft/lbs and the crossshaft bushings to 90ft/lbs.
Moved on to the lower control arms and that is where the issues started. Tried installing the new crossshaft to 100ft/lbs but the bushing isn't fully seating before hitting the 100ft/lbs. The bushing isn't even seating into the rubber bushing inside the arm. I tried unthreading bolt bushing and starting over with the same results. I reluctantly put the impact on yhem and see if I could get the threaded bushing to fully seat in the arm. Still no luck. I decided I probably stop and seek the advice of the board. Am I doing something wrong, anyone have this same issue? I am using new geniune moog crossshafts. The first 3 pictures are the lower arm, showing how far in I can get threaded bushing. The 4th ahows how far I could get the threaded bushing i to the upper arms. |
03-26-2023, 06:38 PM | #2 |
Re: Advice needed on a-arm rebuild
Stop , Take it apart , The zerk grease fittings go in last , Do you have a vise ? The caps have to be installed evenly , one turn on the left, then one turn on the right, etc do you have new lower U bolts to install the lowers ? if you don't have a large vise there is another way , This should help .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-26-2023, 06:58 PM | #3 | |
I have a vise and can try that. I was just concerned that I am having to apply more than 100ft/lbs to the lower crossshafts to get rhem to keep going in. |
03-26-2023, 07:05 PM | #4 |
Post Whore
ChevyMike's post in the link helped me get mine done.
http://67-72chevytrucks.com/vboard/s...d.php?t=508095
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-26-2023, 08:08 PM | #5 |
Who Changed This?
Pretty sure I had to use torque above the final torque spec to get my lower control arm bushings installed, but it's been years. But then, I was used to using slugging wrenches for final torque on steam line fasteners, in the Navy...and you don't send that pencil-armed recruit up there to do it.
03-27-2023, 07:49 PM | #6 |
Post Whore
Uhggggg! Slugging wrenches. Hard work and nothing else.
03-27-2023, 07:52 PM | #7 |
Who Changed This?
Bos'ns mates aren't the only sailors with forearms like Popeye!
03-27-2023, 08:24 PM | #8 | |
I'm lost by the OP's 15 ft. lbs. for ball joints? The chart Grumpy provided should help, and he helped me to install mine. Good advise on the vise. Equal turns and even, with grease. If a bushing doesn't go on smoothly, start over again. Use your original zerk fittings if possible, they're far superior than replacements.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-28-2023, 01:11 AM | #9 | |
03-28-2023, 09:55 AM | #10 |
I had just blasted /primed and painted my control arm shafts and A-arms and I really didn't want to trash the paint using a vise or rolling them around on the garage floor . I explained how to install them without paint damage in this thead below starting on post 5 .
https://www.67-72chevytrucks.com/vbo...d.php?t=795425
03-28-2023, 10:06 AM | #11 |
Replace old worn out lower U bolts with these Dorman 13503 9/16 on a C 10 you just drill the lower shaft saddles with a 9/16 drill bit from the bottom .
https://www.dormanproducts.com/p-1632-13503.aspx
03-28-2023, 04:55 PM | #12 |
Ah, got ya.
